efinque said:
I think the MIDI in Cubase just isn't suited to the demands of todays music, EDM in particular.
No chance. Cubase completely blows away Ableton in terms of it's midi capabilities. There are lots of us "EDM guys" that use Cubase. I use Ableton exclusively for my live sets (well over 1000 shows) and I use Cubase exclusively now for production. I consider myself an advanced user in both DAWs.
Obviously a lot is going to come down to personal workflow, but here are just a few specific things that you can't do in Ableton that you can easily do in Cubase:
Freezing VST instrument tracks without freezing the audio plugins on the track: IE: You can't freeze an ableton track that has an external sidechain on it. WTF?
The grid does not adjust for swing quantization. You can only quantize the notes within clips themselves. So you can't write new stuff in an already established swing-oh yeah-you can't even make your own swing on the fly, you have to audition the ones they have or drop an audio track to try and match it.
No individual MIDI not expression.
The quantizing options aren't even close. It's insane the amount of control you have over quantization (lengths, beginning, end, overlap, iterative adjustments, etc). It's certainly not easy to know all the things that Cubase can do with quantization, but it is a ton.
The logical editor...
You can't send external CC without using buggy third party M4L patches.
And that's just a few midi things. For me the number one killers in using Ableton for any serious production work:
No VST3 support
You can't batch export stems or tracks.
There is NO REAL MIXER VIEW. Trying to do a final mix on a project with 100-200 tracks makes me want to stab my eyes out. You can't hide tracks or groups, etc.
And the worst thing of all-and I will say this has only been my personal experience, but it has happened on a number of occasions-when I get projects that are up over 100 tracks or so and I have to have a bunch of tracks frozen and Ableton is working hard, I have found the timing of the project to get a little lose. It's like there gets to be some variable latency between the tracks and things start to fall apart a little bit. It is very disconcerting.
There are a few things that Ableton has that Cubase doesn't have that I miss in production:
The Drum rack is great! Super fast and easy.
Cubase's drum track does not compare and is a little buggy.
The Audio Effects Racks are a great way of creating effects chains. The parallel chains within the effects rack is awesome. Super fast, flexible and very powerful. it takes a long time to build similar effects in Cubase.
Clip view is a super fast way of building a track. Obviously Clip view is the single biggest thing that Ableton has over every other DAW. It's great and things like Clyphx make it even greater. Without Clipview I would not be able to do my live show.
MIDI mapping of external gear is really simple with Ableton (as it should be!) It is a travesty that Cubase makes mapping external gear so hard.
Push is awesome. I wish Push worked with other DAWs because it is (in my opinion) hands down the best controller built.
Aside from these EDM focused things, I just have to leave two last non-EDM specific thing:
Comping is a horribly sick joke in Ableton
There is no Score editor in Ableton
Cubase is not an easy DAW to learn because it is very deep. But I think it's a big mistake to think that it is somehow a lesser program in terms of MIDI or production. Personally I think it has every DAW thoroughly beat in terms of MIDI and for Audio the only thing that I really know of that Pro Tools has on it is that the Cubase "track versions" is totally lame compared to "playlists".
It's been an interesting last two years or so for me to really go as deeply into each of my DAWs as I can. The standard internet thing to say is that "every DAW is basically the same" but once you start to really push them then that is when you start to see where each one really shines.
