Stagefright13
Just look at schematic all mine will go into slam mode. By buttons or switches. Same thing. http://www.stagefrightrecords.com/P1020378.JPG
dmnieto said:I did keep the 1:2 myself...
You just need to split the resistors on the 4:1 ration on each of the series and wire the intermediate position to the additional switch position=> substitute the 150 for a 68then 82 ohm and the 47k in 20K then 27K
Bobby Baird said:So, the extra 2:1 resistors will be piggy backing on the 4:1 resistor location on the board, but the 2:1 resistors legs will only be soldered on one leg of the 4:1 resistor board location. With the other 2:1 resistor legs soldered directly to switch?
velo-hobo said:dmnieto said:I did keep the 1:2 myself...
Thanks for that info dmnieto - I knew it must be relatively simple, and looking at the schematic that makes a lot of sense. You are referring to the Rev D schematic, yes? In the Rev A schematic, the first resistor on one side of the series is 120ohms rather than 150. I would guess that a 56 and a 62 would be appropriate substitutions in this case.
How did you wire your SLAM! mode then? From reading elsewhere (and looking at the schematic) it seems it's really just the 4:1 and 20:1 buttons that are creating the effect. Did you just wire it the same, 4:1 and 20:1 switches closed in that mode?
Also, the rotary switch ratio boards that mnats provides are designed for the 5-way switches. I think there will have to be some clever wiring going on in order to make the 6-way work with the existing boards and the 2:1 ratio. I assume since you designed your own board that this wasn't an issue for you.
Almost makes me want to give in and order the 5-way switches, but I'm still populating the PCBs so have some time to ponder it...
velo-hobo said:Can anyone who's done a HPF mod on the hairball 1176 report on how they achieved it and at what cutoff frequency for the sweet spot? dmnieto? I suppose I could just try when I get to that point since it is a very simple mod to experiment with, but reports from someone who's already done it would be helpful.
[Edit - I did some more reading and I'm realizing that the desirable cutoff frequency is heavily dependent on program material - but for a single frequency option, maybe something between 100-200Hz is best? Thus .018 or .022uF might be the way to go. Will have to experiment!]
I think I will use the bypass switch location on Dan's case to implement the HPF since I don't plan on putting together a relay-based true bypass for my current builds. I already stuffed the faceplate with a DPDT switch too so it is ready to go.
