abechap024 said:
I ran into a ton of problems most of them relating back to the single sided PCB boards from Mnats having broken traces on them, right around were I soldered in components (don't know if they were old boards or what) Maybe I don't solder gently enough
I designed the boards, but I have never sold them. So the boards you have cannot be "from" me.
That said, I received two boards from the first batch done for Hairball and had no problems with broken traces. I think you're right - you may need better soldering practices. Can you post a picture?
atticmike said:
well I don't have to meaning that I could practically stuff both boards and power them with the supply?
On my Rev A, D and F/G boards there is an outline around the power supply components (which can be left off if using a separate power supply) and a screen layer legend marking where the +30 and -10 Volt rails are connected. Grounds from each board are connected as per the wiring guide and tied to a common point on the chassis. If this seems unclear please don't attempt the AC wiring without help!
