andre tchmil
In case someone needs Neutrik NTL1's for this project, I'm selling some in the black market .
My pair do not have a 6dB loss... maybe double check that the are connected w / balanced in / out correctly.I did notice that when it is switched in i lose about 6db in volume. i remember reading one of AndyP's post mentioning using a 2:1 transformer to make up the 6db loss of the DOA, but it was sort vague and no one else has mentioned it so far. Any ideas?
that's pretty nifty! How are you liking the extra frequencies?JamesW said:Thanks for this project sounds great. Here is a pic of the extra caps on daughter boards that worked out quite well. I used knobs and "L" bracket from Classic API.
ouch! Yea the 5534 needs to be pulled out if you're using doa'sreboot said:hello
sorry for that question ...
if i want to use doa , do i have to remove the amp op under them ?
i put everything and my doa's burnt . :-\
thank you.
Yes. You can always reduced the range of a pot by replacing with a smaller value pot, with resistors on both sides.Another question... Is it possible to limit the amount of cut/boost by simply changing the value of a few resistors, as in the sontec mod? I'm not likely to need more than 5 or 6db.
dmp said:My pair do not have a 6dB loss... maybe double check that the are connected w / balanced in / out correctly.
dmp said:A few thoughts -
Losing 6dB means that your signal is dropping in half. 6 dB is also the amount the output balancing stage will add - why? Because the unbalanced signal (input to r16 on the schamatic) is inverted by the U4 opamp stage to create the (-) for the balanced signal. Think of your unbalanced as a simple waveform - create it's opposite phase - and then the (+) (-) when seen by a balanced input has the voltage doubled.
So where to look? Is U4 working correctly? You should be getting 6dB of gain from the unbalanced to balanced signal there at the output.
dmp said:Also, to help understand the circuit, the input amp, U1, is a differential inverting amp stage. It creates an output based on the differences in the (+) & (-) input. Because the input r1, r2 are 20k, and the feedback r3 r4 are 10k, the gain of the stage is 0.5, so there is a 6dB decrease.
