Potato Cakes
Hello, Everyone,
I've been working on a custom cue mixer for the studio I've move into that has a simplified personal mixer station and a 75W headphone amp (2x 75W amps tied together for stereo headphones). The system that was in place was a Hear Technologies system which it's headphone amp would start distorting when used at levels needed for full band tracking sessions. I believe Mytek has one that is 12 channels and has a hefty amp built in it, but these are pretty expensive and require more expensive multi pair cables. I also wanted to avoid having a massive amount of cable to manage in a small space. So my thought was build a system that used a single shielded CAT5e/6A cable to send 6 unbalanced lines to a small mixer and return 2 lines for a passive stereo mix back to a mainframe that would provide make up gain and balance the signal and then send to a multi channel headphone amp and then out a cue cable via XLR back to the mixer for headphone signal. I got every up and running and it does exactly what I intended and it has plenty of power to drive 32 ohm headphones to make them much louder than I would ever want to listen to something, so for functionality it is a success. I tried to make with as minimal off board wiring as possible and the 40 pin IDC connector is directly compatible with the JLM 12PAK Blue amp.
But it is not quite as perfect as i would like. It does have a low level buzz in it the system that gets quieter depending on where the level knobs are turned. When anything signal is passed through it this is a non issues, but it is still there. I suspect having the large transformer in the unit has something to do with it. I will say that when the CAT5e cable is pulled from the unit and just the cue cable is connected, it is very quiet, so I know the noise isn't being induced from the make up gain to amp out.
There is also low level cross talk that can be heard even if the level control for the channel is turned all of the way down. I am using 15k resistors for the bus resistors which may be the less than optimal value for this application. There are 5 inputs on each summing network (5/6 are fixed stereo) so that gives me 3k bus impedance. The spec sheet for the NE5532 says its input impedance is 30k minimum and 300k typical, but I don't know if that is correct number to use when trying to match impedance. The other mixers aren't finished yet as I am waiting on the stereo jacks and I'm going to try a couple different summing resistors to see if I can better results. I have also read where the output of the summing network can be strapped with a resistor to ground to change the impedance but again I'm not sure is that is suitable in this application.
The mixer in the photo is the first one I made got mangled as I miscalculated connector clearance and had to move the XLR and etherCon around to make it fit. The upside down XLR was corrected.
I'd be curious to know if there is a fairly simple passive solution that would solve some of the signal bleed when the pots are turned all of the way down. I think the issue is related to voltage getting into the ground potential since this is unbalanced. I know I could have used another op amp after the potentiometer and then panning and summing network, but I would have had to have put them on the mixers and that would require power which I didn't want to have to deal with running power and adding to cable mess.
I'll swap out the PSU sometime this week for the SMPS and see if that helps with noise. It would be nice to at least have the buzz issue sorted. I can deal with the cross talk if I have to.
Paul
Paul
