john12ax7
You can also look into ARTA software, it's PC though so you need an emulator to run on Mac.
It's not as simple as it seems.lsburden said:There are several. First stop would be Sweetwater.
I know of the Focusrite Scarlett 2i2.
Tascam just released one.
I think there is also a Behringer model.
Steinberg...
Search the Sweetwater website.
cyrano said:Look here:
https://www.minidsp.com/products/usb-audio-interface/mchstreamer
USB, ADAT, 115$, 384 kHz, Win, Mac, Linux.
Or simply buy a UMIK1 if you only do acoustical measurements:
https://www.minidsp.com/applications/acoustic-measurements/umik-1-setup-with-rew
Gold said:Do either of those have analog inputs? I didn’t see it listed in the specs. It looks great but no analog ins would be a deal killer for me.
abbey road d enfer said:It's not as simple as it seems.
I ordered an Icon interface that was just perfect, all balanced line level, built like a tank, no knobs, but the frequency response has about 3dB variation across the range, which actually falls short of 60kHz with 192k SR. Had to send it back.
The Behringer, I have, UMC202HD, I could never make it work at 192k; even at 96k, it's not stable. It's used as a door stop.
The Scarlet is promising, but the frequency response at 192k is not spec'd. They just say 20kHz at 48k SR.
I don't know about a new Tascam, the one that seems to be actual doesn't run at 192k.
Steinberg say 22k.
Steinberg say 22k.
warpie said:Maybe a bit off topic but can you recommend a 2-ch interface that would accurately measure frequency response up to 95ish kHz (i.e 192kHz interface)?
john12ax7 said:Most likely you would need something that does 384k or higher. All the 192k ones tend to have early roll off. Which does make sense, as part of the reason for higher sample rate is you don't need an ultra steep filter.
Winston O'Boogie said:Thanks for the further suggestions and keeping the conversation going regarding other issues.
Regarding flat frequency response to FS/2, one affordable interface I found was the Audient ID22 or ID44 which states response to be flat (+/- .5dB) from 10Hz to FS/2 via the direct to AD converter return points and the DAC outputs. The problem being that maximum sampling rate is 96K only.
Stepping up in price, The RME ADI‑2 Pro with a 768kHz max sample rate and states that at 384 kHz, response is -1 dB: < 1 Hz – 124 kHz.
For what I want to do, decent FFT and spectral analysis up to an octave above audio is sufficient. Anything above that I need to do I'll do it the old fashioned way with a generatorand a 'scope.
warpie said:As I mentioned before there's that new motu m2 interface which costs a couple of hundred euro and it seems very decent.
Personally I think I might end up with a qa401 sooner or later. Still trying to decide.
