Winston OBoogie
lsburden said:Only 96kHz sample rate though...for $169.
The M2? Scan in the UK says it's 96K but the MOTU site says 192K
Winston O'Boogie said:The M2? Scan in the UK says it's 96K but the MOTU site says 192K
lsburden said:Motu M2 User Manual
https://cdn-data.motu.com/manuals/usb-c-audio/M_Series_User_Guide.pdf
Frequency resonse and other info on page 25.
That is clearly not what I have experienced; I must say I've been equally disappointed, though.lsburden said:I think most of these budget USB Audio Interfaces have very similar features and specs.
I don't know any company that still uses MLSSA as its principal measurement tool. It's been replaced since long by systems that don't need internal PC cards such as CLIO, Klippel and EASERA, or even REW. The fact that their website has not been updated since 2009 seems to testify so.Tubetec said:I was wondering about MLSSA
There's no doubt that many current and pastinterfaces provide adequate performance over the "traditional" 20-20k bandwidth. The big issue is finding one that extends to about 80kHz; that would mandatorily be capable of Quad Speed operation. It turns out that several interface boxes capable of 192kHz SR have a frequency response that falls significantly short of the Nyquist frequency. Very often frequency response vs. SR is not specified in mfgrs litt.alexc said:When I'm testing with REW analysis suite, I use an interface that has 4x 'line input' and 'line output' balanced connections ...
One pair of I-O is for REW analysis .. ie. a main 'DUT' send and return, and also the 'Loop Back' send and return.
The other pair of I-O I use to 'audition' stereo audio, to an amp and speakers .. could be a media player - most of the time - or a favourite intrument channel or so.
It helps nicely to have 'a pair' for testing DUT and 'another pair' to listen on the speakers .. while you go .. but completely seperate from the 'signal generator' at all times 8)
SO - apart from that, I do like to use an SPDIF pair too, for digital perspectives.
As far as the input and output range goes, plenty of cheap m-audio do balanced I-O up to around 10Vpp sine with really high fidelity as 'a loopback'. Which is fairly decent, I think.
Much, much higher fidelity than almost any reasonable cost hardware signal generator box out there.
For anything I need to drive higher than around 10Vpp, I use a step up 'test bench' transformer *and/or* a solid-state amp module
-> ie. for various kinds of testing of intermediate level and distribtion amps and so on
Some solid state 'balance-debalance' .. and 'straight wire gain' .. modules let me get to some of the fine detail for less than 100 dollars.
For anything I need to receive higher than around 10Vpp, I use a 'psuedo balanced attenuator' box
-> ie. for tube stuff of all kinds
If the power is higher, then I can link in a 'load box' into the above scenarios and a solid state power amp module with still very high levels of 'measurement channel integrity'
Covers most audio ranges with quite amazing fidelity and a good launching point for the more 'hi resolution' endevours.
My 100 dollar m-audio box Profire 610 does all the above, in a way that if you accidently 'bork it', it's not too big of a deal.
Admittedly, it is old so one needs to consider their hardware platform.
I think I get something like 0.0015% at least, in most testing scenarios for the 'testing channel' in real life situations.
[firewire in my case - up to fs 96KHz with no probs]
For more modern money, I'd love to try some of the nice ones out there.
Murdock said:Has anyone tried this little Thing?
http://www.pmillett.com/ATEST.htm
Sounds quite usefull.
That is a very interesting question. There are loads of interfaces out there, both cheap and expensive ones, with a quoted 192KHz sampling rate but by far and away the vast majority do not quote specific analogue bandwidths at each sampling frequency. In fact in general their analogue specs are woefully inadequate. All the ones I have seen simply quoted a blanket 20Hz to 20KHz..Winston O'Boogie said:Hey Wall,
Yep I've seen the Beis stuff and it looks pretty decent. At quad sampling (192KHz) he states that frequency response is flat up to 80KHz which is nice. At lower sampling, the response is of course F/2.
Can this be bettered using an off-the-shelf built device? I don't know as accurate specs seem to be thin on the ground.
It should surely be possible that the purchasing power and clout of a big company could get you to the same place at lower cost but then, with cost X 4 being the usual markup for commercial stuff, dunno?
