atlanteansparrow
New member
- Joined
- Mar 21, 2009
- Messages
- 2
Hello folks,
This is my first post at DIY and although I've been following some of the interesting threads that appear on this board, this is the first time I really need your tech and sound advice.
Here's the thing: I have a studio and been thinking about getting a summing amp for quite a while now.
I have the possibility of building my own project summing box, which I'll build with a technician or for more or less the same money, buy a summing box made by Velvet audio.
What I can build is a tube 8x2 summing device with four 12AU7A RCA tubes as input, a couple of 12BH7 Westinghouse black plates for the output and Jensen output transformers. It has no pan pots or individual level controls as well as no input transformers.
The other option is a Velvet Audio SA-14-4 Vintage line mixer. It is based on a Neumann dual summing amp with floating balanced inputs & outputs. The level and pan controls are realized by a passive circuit.
It comes with Haufe transformers.
The gain controls are working as a pad. The master volumen enables a maximum gain of +10dB. The Pan pots have a center click.
The unit has 14 balanced mono inputs + 3 balanced stereo inputs. An additional feature is a stereo balancing amp for the fourth stereo input.
The SA-14-4 is running with an external power supply. It works from 100V to 240V main voltage.
The included dual summing amp is a Neumann V475. The dual balancing amp is a BFE Filtek V1157.
I'd be very interested in knowing your points of view regarding the two options. This is a tough one for me, what potential do you see in my tube summing box? Do you think it is worth going that direction? Or would you just go the other way? any experiences with Haufe transformers and thatt Neumann model?
Of course the ultimate decision is mine, but I think it's wise to listen to what you people have to say.
Thank you very much!
M
M
