Originally Phips 24V nominal adjusted to about 28V, then my own 32V supply.What was the input voltage to the 7824 / !0R Resistor ?
+1 as I've shared before, I once black-listed 3 terminal regulators from a major US manufacturer when they refused to provide a maximum noise spec for their 3-terminal regulators. In a big console everything can matter, and noisy 3 terminal regulators can matter.I'm not a fan of onboard regulators in mixers, particularly 78/79's. They inject noise in the "ground" path that can too easilly pollute the whole system. My first mixern when I was wet behind the ears, had a 7824 on each channel (yes, no bipolar PSU at the time). I was not pleased with the noise performance.One day, as an experiment, I replaced the 7824 with a 10 ohm resistor. The noise improvement of the summing amp was significant. After that, no more on-board regs. Saves heat too.
I never tried with 317/337 though.
Does a 3 terminal regulator produce significant noise in that case that the input only gets pre-cleaned DC? Is there a correlation between the voltage the regulator has to drop and the noise it produces?+1 as I've shared before, I once black-listed 3 terminal regulators from a major US manufacturer when they refused to provide a maximum noise spec for their 3-terminal regulators. In a big console everything can matter, and noisy 3 terminal regulators can matter.
I accept responsibility for a large console design that was susceptible to regulator output noise (hiss). I suspect it was related to power supply decoupling and grounding systems.Does a 3 terminal regulator produce significant noise in that case that the input only gets pre-cleaned DC? Is there a correlation between the voltage the regulator has to drop and the noise it produces?
I could write a small book on the subject
Love the schematic!! De-coupling in the supply lines, too! This should be the norm for circuit designers - and it has the added benefit of guiding the PC board layout. Thinking in terms of current, as you say, is the key!The way I usually put this is (for clarity and to have something in mind when looking at a circuit):
1) Current always flows in loops and along the path of least impedance.
2) Ground isn't! (Ground is a signal line).
3) Voltages are commonly the consequence of currents flowing in a non-zero resistance/impedance.
And keeping these rules in mind leads me to draw schematics often like this:
In other words while most EE's work on a "Voltage" focused paradigm (because all active devices are voltage input devices), but it is current flow that actually matters and the impedance's the current flows in and even the coupling between the (power/ground) lines current flows in and the signal lines.
This is as valid in Audio, as it is in industrial and military electronics or digital (non-audio).
Thor
There will always be noise currents dumped into sundry grounds.Regarding the question of injecting noise into the audio ground - is this a problem when decoupling with small caps, say 100bf? Isn't any noise far outside of the audio band in this case? Would low level out-of-band noise dumped into the audio ground affect proper functioning of an op amp (I'd guess that higher up noise could cause a problem even at lower levels because of loop margins, slew rate and other concepts I do not mathematically grasp)? This is inside a console with twice regulated power and lot's of shielding.
No, it seems to work very well with the 100nf caps. But 10uf to ground didn't cause any noise problems either.There will always be noise currents dumped into sundry grounds.
Signals need to be handled differentially, grounds are not 0V
Do you have a noise problem ?
I've conducted more tests and got the best results in the console decoupling NE5532/5534 with op amps driving no external loads by decoupling with 100nf ceramics directly at the power pins and connected to the nearest ground, with the addition of a high-ESR 10uf electrolytic rail-to-rail.
Bad sonics and high THD with the original layout (insufficient decoupling). Oscillation with certain brands / production dates of NE5534 in certain spots (in a circuit designed for the NE5534). Higher THD of a nearly identical stage at a different location on the PCB.What are the parameters wrt "best results" ? Or to put it another way - what were the deficiencies with alternative schemes ?
Unfortunately not, sorry. I jump around a lot with levels and frequencies to find differences between the channels decoupled in different ways. I have not currently connected equipment that enables me to sensibly measure absolute THD levels with. And the signal travels through the rest of the console afterwards still, so there is no way to test circuit parts in isolation at this time.Thanks. What degree % or dB of increase in THD ? Any figures for IMD ? Any comparison with something like 2 X 10u from rails to 0V somewhere on the PCB then either 2 X 100n from rails to 0V or a single 100n R2R near the NE5534 ?
Briefly - the noise "far outside the audio band" is a big problem for op-amps because the op-amps have no open-loop gain at those frequencies to correct their open-loop non-linearity (which is often quite horrible). This non-linear behavior turns the amplifier into a classic "mixer" with sum and difference spectral components being created. Many of the difference components are in the audio band and are harmonically unrelated (discordant) with the original signal. The late Deane Jensen described this in his 1988 AES paper about "Spectral Contamination". Band-limiting between stages is one way to reduce the accumulation of the contamination, but controlling contamination of "ground" is also necessary. Adding series impedances in power rails greatly reduces ground contamination by attenuating noise from other stages feeding from the same rail - having bypass caps right at the supply pins of op-amps is a good thing (maintains stability) but all the benefit of using "star" connections in the grounding scheme can be undone by forgetting to either add the series impedances or "star" connecting the supply rails as well.I've conducted more tests and got the best results in the console decoupling NE5532/5534 with op amps driving no external loads by decoupling with 100nf ceramics directly at the power pins and connected to the nearest ground, with the addition of a high-ESR 10uf electrolytic rail-to-rail.
