I know it's a slight subject of disagreement with JR. My view is that condenser mic noise and room noise have a noticeably different sonic character than noise due to electronics and many musicians discern this difference and understand that room noise is not the console's fault.
I doubt we disagree significantly. I repeat an old warning of mine to lower expectations and avoid too much focus on bus amp noise. Even with a perfect summing amplifier, the console would still have an audible measurable noise floor. IMO a major benefit of managing sum bus noise gain/loop gain margin is improved phase response, and lower distortion.
Some noise sources sound different and some pretty similar. Mic preamp noise will have pretty much the same sound character as bus amp noise. All the mic preamp's noise will combine incoherently so not Nx more like square root of N. Room noise, stage wash, whatever of course varies wildly in sound character. I don't claim that bus noise doesn't matter, only that it must be held in perspective as one of multiple contributors to noise floors.
For today's TMI about noise floors, at Peavey we had a house part number for a 5532 what was selected for a guaranteed noise floor spectral response. Specifically parts with dominant 1/F noise were culled out. This was so when customers listened to noise floors with everything turned up to 11 heard a well behave white noise.
It would certainly; we're counting on you io report the results of the comparison.
I am not aware of any way to swap out op amps inside the transamp (a hard potted module). IIRC Paul Buff used a TL072 inside which is fast enough for audio and relatively quiet. Perhaps people are talking about replicating the Transamp topology (aka Cohen but perhaps not the summing application)?
I suggest you go to the proaudiodesign forum. There's a whole thread there.
No. You have to grok the concept of OSI, which has very little to do with impedance matching.
So this makes the impedance of the CB stage about 10 ohms. Actually a little more due to the emitter spread resistance. But it results in a very low noise voltage density.
It's like this 10 ohm resistor was in series with the source, so it should be minimized, until the noise current becomes too high. (noise current increases as base current increases)
I can't read any labels in your pic.
Anyway I'm always suspicious about this type of arrangement. Makes me think that the designer was not quite sure he had made the good choice, so he left that open to someone else.
I've seen several mixers that had multiple "grounds", in particular one bus for the summing amps "ground". The most common mistake is forgetting to put a sampling resistor between channel ground and this bus. Anyway it doesn't play well with the most common arrangement that disconnects the feed resistor from the bus on unused channels.
An extreme case would be only one channel routed; with the summing amp ground sampling all the channels, the residual noise of all the channels is still there.
I've often found that I got a better overall performance using this summing amps bus to reinforce the main ground bus.
I would be cautious of allowing general ground currents to corrupt signals. A "signal ground bus" is more of a signal than a ground, IMO.
wrt to differential sum bus topology, if both + and - buses are active and fed audio signal, 10k resistors on both may increase Johnson noise +3dB, but the coherent signal increases +6dB for a net gain of 3dB to S/N. If the - bus is just summing all the local channel grounds, common practice is to use on the order of 100 ohm resistors. This preserved the differential math while reducing the Johnson noise contribution.
Yes, I noticed that. It may be an attempt at fixing an imaginary offset problem or a stability issue...
Have fun..
