k brown
"Diffuse Field" and "Free Field" are entirely about distance.
Please do tell, give us the infosI know of only 2 SDC cardioids which are -3dB @ 50Hz in free field and one of them is mine from circa 1980. ALL other SDC cardioids have worse LF.
eg Schoeps MK4's free field is above 100Hz.
Definitely let us know, I'd been eyeing those too, interested to hear how they are
Well they arrived. Look and feel great! Their capsules and the Superlux S502 MKII capsules fit on each other’s respective body, but neither of them work (no sound) on each other’s body.let us know please when you receive the 92€ Ali SDC mic (Schoeps look) and how it sounds with the chineese original caps.
Interesting. And thanks for sharing your findings. Did you figure out why the capsules did not work on the other body? Does the CML-300 have an electret capsule with JFET maybe?Well they arrived. Look and feel great! Their capsules and the Superlux S502 MKII capsules fit on each other’s respective body, but neither of them work (no sound) on each other’s body.
Just at home, I plugged them into my Big Knob and listened on my talking voice (very baritone). The CML-300 sounds pretty-damn good. Great cardioid-pattern and off-axis sounds really good! Very sensitive to plosives close-up, like the S502 MKII. If I had to guess, maybe a couple DB more noise than the S502 MKII and certainly much more proximity-effect!
Hum, they (Superlux & CML-300) seem to have exactly the same capsule's connexion... and I don't think the CML is an electret...Well they arrived. Look and feel great! Their capsules and the Superlux S502 MKII capsules fit on each other’s respective body, but neither of them work (no sound) on each other’s body.
15.0 of https://groups.io/g/MicBuilders/files/Ricardo/README.docPlease do tell, give us the infos
I make a perfect cardioid to have -27dB 1m 180 response at 1kHz. Otherwise, your shape is sorta correct.Maybe, “free field” means “plane wave field”, so, for example, very large distance in free field conditions. With an established manufacturer, I would hope for a standard measurement distance of 1 m of published graphs if nothing is explicitly stated (I think the Line Audio graphs are exemplary in this regard). Here is a quick simulation for a 22 mm cardioid at different distances (based on the formulas given in the Shure paper).
Not quite."Diffuse Field" and "Free Field" are entirely about distance.
Thank you15.0 of https://groups.io/g/MicBuilders/files/Ricardo/README.doc
You have to join.
The Calrec cardioid capsule was my baby. My plane wave tube wasn't quite as long as Jo Wuttke's.
