Marceldarcel
Member
Hello dear all,
I am going crazy and can't make progress with my racking project for the v372 or V372/1. Everything works, except for a constant hum or buzz, which must be related to the grounding.
I had the V372/1 recapped under the supervision of an electrical engineer who is also into vintage German broadcast stuff. All capacitors are new.
I just received the v372 - it is actually the old version without any additional designation. I have the manual for it.
Both amps have a slightly different pin layout (for example, the "old" one needs a bridge between 5/6, which is NC for the V372/1. Also, 0V on the V372/1 is at PIN 13, 21, and 29, while on the V372 it's at PIN 7/8, 21, 29).
To avoid confusion, I want to focus here only on the V372/1 with the two blue NTPs.
Here is the pin layout:
1: Input (a) (+680 ohm resistor)
2: Input (b) (+680 ohm resistor)
3/4: NC / Bridge
5: NC
6: NC
7: NC
8: NC
9/10: Rg (220k Log)
11: NC
12: NC
13: 0V
14: NC
15: NC
16: NC
17: NC
18: Output (asym.)
19: Output (a)
20: Output (b)
21: 0V
22/23: Bridge
24: NC
25: NC
26: NC
27: NC
28: NC
29: 0V
30: Chassis
31: 24V
I have attached an image of the V372/1 board from which the pin layout can be seen. Where should I connect the shield? I have tried pretty much everything I found in forums and on the internet. I also attempted to follow the schematics of the 376a and 376.
There is a Gearslutz thread about humming on the V372/1, but unfortunately, the resolution is not revealed there. There is also the article "v372/1 Racking Completed" here. Looking at it, it can be seen that the shields of input and output are connected to Pin 30 and Pin 29. Even if I omit Pin 29 or 30, nothing changes for me.
My V376 is up and running smoothly. It doesn't cause any problems.
I have already swapped the lab power supply, all cables and XLR jacks, as well as pots. I also took my test lab to another house...
I am extremely grateful for any help!
Best regards,
Marcel
3/4: NC / Bridge
5: NC
6: NC
7: NC
8: NC
9/10: Rg (220k Log)
11: NC
12: NC
13: 0V
14: NC
15: NC
16: NC
17: NC
18: Output (asym.)
19: Output (a)
20: Output (b)
21: 0V
22/23: Bridge
24: NC
25: NC
26: NC
27: NC
28: NC
29: 0V
30: Chassis
31: 24V
Best regards,
Marcel
