man-bot
- Joined
- Dec 20, 2008
- Messages
- 87
I have a Tascam MS-16 in reasonably good shape I have aquired however I am having an issue with 4 of the rec/play cards.
On these 4 cards they will record 10khz just fine, however as the frequency is moved lower the level goes down as well. At 2khz there is no signal registering.
The problem is definitely with the audio cards as it follows them to know good channels, and vice versa - good cards work fine in the channels where the faulty cards typically reside.
This is where I have traced the problem to:
I have swapped C22, C24 and R49 as well as the bias trap with no luck in fixing this and am feeling a bit stuck. Everything seems fine up to where C22 goes to C24 and R49 - this is where I see a voltage drop as the frequency is swept lower.
I am using the oscillator on my mixing desk to provide signal and tracing with a fluke scopemeter.
I you have any thoughts of what to try I'm open!
You can grab the full schematic if requried at home.cogeco.ca/~michael.lett/
Mike
Mike
