I just finished this project and wanted to show it off a little bit. Thought you might like to see the results. I had one last set of original transformers (UTC HA-100X, A-24 and Triad R4A) and wanted to do something a little different than just another LA-2A clone, so I decided to go back to the beginning and make an LA-1 clone. I was able to find the original meter, meter switch, and power indicator lamp, and used vintage toggle switches for the Power and Comp/Limit switch (even though the original LA-1 didn't have that switch). The Pièce de résistance is the original Teletronix T4A that I'm rebuilding and will use with this unit. I took some liberties to improve performance and usability, the Gain and Peak Reduction pots are Alps Blue Velvet, the output coupling cap is a Solen film cap, and many of the critical audio paths are shielded using Mogami wire, where in the original they were wired unshielded. And the electrolytic caps are all modern, of course. Still a little tweaking to do, but it's about 99% of the way there now.
![Teletronix_LA-1_Front-2.jpg](https://proxy.imagearchive.com/24f/24f77ca9a71bb6aef13777989f92a220.jpg)
![Teletronix_LA-1_Rear-2.jpg](https://proxy.imagearchive.com/428/42843de6cd85abcd6325032474dd2f01.jpg)
