From the BOM
4 * 1/4W MF 1% R205, R206, R207, R208 A1, A2 RELEASE
10 * 1/4W MF 1% AOT1, AOT2, AOT3, AOT4, AOT5, AOT6, AOT7, AOT8, AOT9, AOT10
Testproc:
1). +/-20v JP1...6, TP+20v, TP-20v
2).Unity gain Initial gain is set by AOT1,2
3).Distortion w/o compression minimum distortion adjustment AOT 7,9
4).Distortion at 20dB GR distortion under hard compression adjusted by AOT8/10, usually 10R is fine
5).Com threshold Com threshold adjustment: AOT3,4
6).Lim threshold Lim threshold set by AOT5,6.
7).Check: reqresp, max gain, min gain, S/N, timeconstants.
A lot of requests on this , is there any indication what starting values should be for these ?
seems this is a source of confusion with most builders. Looks like a good place for trimpots.
