I built a mic pre based on the data sheet of the THAT 1512 -
http://www.thatcorp.com/datashts/THAT_1510-1512_Datasheet.pdf
I followed Figuare 5, with the phantom power.
To power it, I used something like this -
http://sound.westhost.com/project05.htm
I wanted to have the transformer out of the box and had a 16V ac transformer.
I hook up the pre amp power, works fine. Everything is good, sounds good.
I then added a phantom power curcuit. I used a voltage tripler, 3 diodes and 3 caps. I ran it into an LM317, hooked it up just like the Fairchild data sheet. Pretty standard lm317. I check all the voltages, everything reads good. I then hook up the power going to the 6k resistors, and that is when I have a problem.
First, there is a buzz, and then the sound from the hooked up mic goes out. I have tried with both a sm58 and a condensor, same thing. I undo the power and after a couple seconds the volume comes back up. It almost seems like the 22u phantom filtering caps are loading up. I checked the polarity and it matches the THAT datasheet.
I have checked the wiring, at least a half dozen times. I opened up a box I have that has a center tap transformer, used some alligator jumper cables to power it, thinking it may be the wallwart type ps, but no change.
So, I am missing something here. I have looked at a lot of schematics, this seems pretty standard..
sorry I don't have a schematic to put up. I could draw one up by hand and scan, I suppose, but it is not much different than this -
http://www.forsselltech.com/downloads/schematics/MikePrePS1.PDF
So, what am I missing?
