The best noise gate?
ok, great stuff, i'll check the 6.8k and 1.5k resistors and also check all transistors, i have a few other FET's which i could change, also i could tweak the 50k trim before the 2M2 release pot see if that has any influence?
ok, for some reason there was a 56k in where there should have been that 6.8k before Q6!!
Ive changed to 6.8k now, getting Q6 Drain/Source = 0.075v AC and if i turn the attenuation i can get 0.136v AC
so this works now i think?
still very low output and i've checked Q7,Q8 and Q9 transistors and i have 0.6v difference between Emitter and base, so these look good.
any other ideas?
Yes, this part works. Now what is the AC voltage at the base of Q7?
AC voltage at base of Q7 = 0.003v
Are we sure that 8.2k/82k resistor is correct? I’ve got 82k in there at the moment.
Dc voltages
Q7
E - 8.74v
B - 8.06v
C - 6.27v
Q8
E - 5.63v
B - 6.27v
C - 23.93v
Q9
E - 5.00v
B - 5.63v
C - 15.22v
I didn’t have the ATN pot fully off!, so I am getting the 0.075v at Q7 base!
I’ve traced the signal and I’m getting good waveform until Q8 emitter, so something’s happening after that.
Will look tonight after work, hopefully got a few more days off to finish these.
well i'm stumped?
Q8 emitter = 0.655v ac
Q9 b = 0.655v ac
Q9 e = 0.036v ac
Q9 c = 0.158v ac, but this only settles when i twist SENS pot to open closed? (SENS pot = 50k rather than 22k)
I've checked 15k, 560R and 220R all are correct?
signal input = 0.775v (or close enough!!!) signal output = 0.160v!!
well i'm stumped?
So am I.
What do you mean "open closed"???
Short-circuit at the output?
ok, success in that i've removed the 47uf at output and i get signal here now,  so will try another or happy to try something different?
Ive tried 0.47uf here but still doesn't output, gate works as it should, just need to figure why this cap is stopping the output?
Probably because you have something shorting out the output.
There is nothing there to short?
If I attach to the collector leg of Q9 the scope and have the cap in there is no signal, if I take the cap out I get signal?
Look again. What is the output connector? TRS? Can you post a pic of the connector? How is it connected to the main PCB? Cable may be shorted...
Yep you were correct! Dodgy jack plug, removed and getting clean signal through, all works as it should.
I changed the 82k to 8.2k by the 120k resistor, seems to not make too much difference but I might be wrong!!
One channel down, 3 more to go!!
Have to laugh at myself sometimes, i'm still finishing the RM68 4 channel gates but i just figured out if i use an AUX channel into a normal channel in protools and put a gate and TRIM on that channel (i use TDM dsp plugins) i can record with gate onto the channel, no need for external outboard.
