mrgrooves666
Well the tension of the ring is holding the rest, and in some capsules, the diaphragm is also glued to the ring.
Yes, so it should be safe. But I wasn't sure at first and that's why I asked. Better safe than sorry...Well the tension of the ring is holding the rest, and in some capsules, the diaphragm is also glued to the ring.
Hi @jp8 here : https://fr.aliexpress.com/item/1005....0.0.1a6f378dwqhzxA&mp=1&gatewayAdapt=glo2fraCan you provide a link?
Jan
Does anyone have a picture of the Audio Technica capsule without the resonator on it? I was researching something and read an article that described the diaphragm as having some sort of pattern embossed into it. The description was making me think of gold drops and the like.
You can actually see the pattern in the last image in this post. KSM32 has something like this as well.Ok 4033 and 4040 gut shots, as well as a close up of the 4033 capsule where you can see a bit of the backplate hole pattern.
4033 - Old:
View attachment 135429View attachment 135430
4033 "A" variation, newer:
View attachment 135431View attachment 135432
4033 Capsule close and detail of holes blocked:
4033A Capsule rear- definitely a construction difference from the older 4033 non-A version:
4040 Current Gen SMD guts:
there is hope, but unfortunately i don't think i can put it back together with the precision required to re-skin it due to the glue residue. I'll buy you a new one in a bit + make you a new one too.Wow! So there is still hope?!
You lending me one was generous, I don't see any serious issues with manufacturing this. I don't think it could have been done with the mass production shop but I'm sure my friend will have a blast with this. I see how they did the isolation between the sides but no clue how they're actually getting it done. It seems like there is machined hard plastic inside the larger ring? I think they might put a blob of plastic in there, wait for it to harden and then machine it. The outer ring seems like it's just a ring, I think the retaining ledge is plastic, which is problematic... But not out of our scope. This is definitely going to be an expensive capsule. I don't think I could offer this at retail for less than $400, which is basically what they go for on the used market so there's not much cost savings to be done here.That‘s very generous!!
Hello ,
Anybody know what are those capsule From Ebay , i ordered some and they were very good :
https://www.ebay.fr/itm/114259676027
Is it just me or does it look like a ck12 style 797 capsule?Slate Digital ML-1
that is it! 1:1Is it just me or does it look like a ck12 style 797 capsule?
CY032:
https://www.797microphone.com/micro...97-audio-cy032-34mm-non-centering-single.html
