LevinGuitar
- Joined
- Jun 13, 2019
- Messages
- 482
SE2200T capsule. Surely used in other SE microphones as well, and I wonder if not by other brands. The mylar seems a bit different (thinner sputtering?) than the average chinese k67
Yes, the backplate construction is also different to other 32mm. SE has less HF boost, but extends much higher in HF than most k67.SE2200T capsule. Surely used in other SE microphones as well, and I wonder if not by other brands. The mylar seems a bit different (thinner sputtering?) than the average chinese k67
Anyone have photos of the capsule in PreSonus PM-2?
Why do you think that's a center-terminated capsule? From the back it look much like the Primo EM-21, but with a gold diaphragm.Could be similar (or the same?) to the first MAudio Pulsar.
Please ignore the green ERO cap, I tried them (the other one is under the pcb) for output but lost some low end because the original SMT caps were even larger.
The PX1 mic looks to me the same as the old Sterling ST51 and company.
It's just a ring of foam.I haven't said so nor I do think that, as well I don't believe the FR curve of that review.
I can't see any reflection on the diaphragm so it could be not gold sputtered neither.
Don't know Primo capsule, so not sure if it's the same
Edit: I googled EM21 capsule and even it don't look the same, it seem to have same weird ring on unknown (to me) material as the MAudio capsule.
BeautifulDavoli 607 wonderful bass and kick dynamic , italian vintage gem from the 60's
Sennheiser KS 70 (MKH 70 capsule)
They're just snapshots from my repair adventure, so they are not the best but may be useful for someone. Just for reference: each backplate is 20mm in diameter, with a thickness of 1mm, while the other part of the backplate is ~0,5mm thick. There's mesh in between to keep debris out. The distance from the membrane to the backplate is set via a spacer with a thickness of ~0,03mm (see pictures).
