The Motown eq
Thank you for your reply.
View attachment 96604View attachment 96605I don't have any knowledge or skills about tube, so I think it will be a transistor circuit.
I haven't picked up the circuit yet, but I'll upload a photo that isn't on the blog.
The lowest and highest frequencies.
Precise inductors and capacitors are required to make a copy.
well with the amount of make ups gain needed could do a pultec style make up amp
As I’ve said in other threads about those Cinema / Langevin 251 / Altec 9061/9062 / Hycor EQ’s, if you’re feeding 10K or higher input Z it works perfectly well to use a 600:10K step up transformer on the output as makeup gain. I’ve done it, I’ve measured it.
a lot of wire footage in that thing, but they did not care as much about noise back then as AM radio was hash city.
awesome work, thank you so much limo.
2 gotchas that I found:
1) C2 @ 12,5kHz is 19.9nF, not 11.9. the value is visible in the bottom pic in post #20
2) all these resistors look to me to have gold tolerance bands. thats 5%.
thanks again, —ps
Thanks for your support.
Some people pointed out mistakes in messages.
I also found one mistake...orz
inductors value uH >>> mH
I uploaded a new file here
https://media-uploader.work/?mode=dl&id=3775&original=1&key=084b283d-a394-4493-a888-0b8f19a50ddf
It seems to be a topic on other forums as well.
Some inductor values were written and some were missing, so I removed them all and measured them.
Some of the written values were consistent and some were not.
The numbers in the table are measured values.
Resistors and capacitors are not measured.
