[silent:arts]
Paul, no problem - fire it up
If you can see inside meter there is for sure some resistance network or just one resistor. Try to play with that 8)Is there a possible solution to this problem? Unfortunately I have already drilled holes for the mentioned meter.
I mentioned many times that VU is connected as DC miliampermeter in this project and it's not "just connect any VU" because ist's connected in series of supply. I doubt that buffer will help in this situation. I'm afraid that you will have to check inside the meter Or to "rescale" zero db... BTW, I'm sure that you must "rescale" (to draw a new scale) if you want to have a real meter valuesThanks shabtek, Moby,
Unfortunately the meter is completely sealed.
I put a 10k trim in series. didn't help. I do not know where to go next really.
perhaps a buffer would help?
A buffer isn't easy to do, the vu is paralleled to a resistor connected to the 130V supply rail.noulou said:perhaps a buffer would help?
No, no voltage change there... You will only see the polarisation voltage...noulou said:Would it be better to stick the vu meters at the cathodes of the 6BC8s?
pin 3 of the 2n6107 via a trimpot to ground?
Which one? Recommended sifam?I use a vu meter in my PM670...
No, but it's an old Pekly vu meter, 3K6 internal impedance, if I remember well it's the same thing than sifam's specs. There's a build in resistor to reach the classic vu meter spec that isn't connected. In my Pekly it's a 3K9, but I'm sure a 3K6 will do fine ( maybe here is my 1 dB error :). I did use it just because it was simple and because I was afraid to burn it. With the pot paralleled, I've got the 0 vu adjust.Moby said:Which one? Recommended sifam?I use a vu meter in my PM670...
the two pin connector pin1 is +, pin two is GND - it is fine what you are measuring there.rrs said:OK when testing for +17V and -17v on the two pin connector pin 1 has +23 but trim won't adjust voltage up or down.
Pin two has no Voltage.
The connectors out next to it seem fine I am getting +23V / - 23V but of course neither trim resistor is adjusting these voltages
rrs said:Any advice on where to start looking would be greatly appreciated.
lolo-m said:rrs said:Any advice on where to start looking would be greatly appreciated.
Stupid questions ;D ;D ;D :
Are the regulators mounted insulated ?
Are you sure you didn't put a LM317 instead a LM117 and so a LM117 instead a LM317 ?
This kind of things happen... I remember the last time I soldered an electrolytic the wrong way :'( :'( :'(
What voltage you measure without tubes? BTW it's possible that PSU transformer is saturating .If it's not too hot go ahead 8)Now for the resistor R15. As I have a stereo version I noticed earlier that 1R is an estimate.
I tried a .86R and measured 5.12V at the heater connector on PSU board. .86R measured 5.21V and .33R is measuring 5.71
I am assuming I may need to go down to .15R should this be right.
