Well I'm in the home stretch now!
Got the EQ working as it should, as well as having tamed the 6as6 pentode/triode switching nicely and finally, balanced up the WCF output section.
Noise floor is pretty good considering all that is going on gain wise here
Today I did some rearranging of a few things in order to nail down the Orange 86 I am using as the front end.
Noise is really good as stable. Able to switch my mic, line and HiZ inputs and use all of the gain available with an acceptable noise floor.
On the line input which uses a 600:600 haufe input transformer and no additonal pad (so far), I am getting noise floors of -82dBu (measured as an spl 20-20KHz) for loopback, -80dbu for maximum nfb and -60dBu at min nfb
Thats for max 35dB of gain (using 6N1P paralleled to Edcor 15K:600 x5 stepdown traffo on the orange86 output).
So firstly I have to say that the Orange86 is really, really good 8) Well done to Charlie Guavatone!
Now I have theOrange 86 working right, I can say that is is just amazing on an electric guitar - a jazzmaster in this case. No messing around - turn it up and what a harmonically rich, slightly compressed and authoritative sound it is.
Easily the best clean electricguitar preamp I have built. Awesome harmonic content I've not yet achieved with triodes
(this is my first pentode pre attempt). This into my Motu audio interface input mixer, rounted back out and to a stereo monitor amp - and old hifi with push-pull EL84s ;D
So - thats *just* the preamp! I still have to fine tune the ef86 operating point for higher gain than the x64 I seem to be getting right now, but basically its rocking very majorly.
Now the eq with drive section is good - totally flat response at the end of the nfb eq+GCA+CF and into the Rude Tube pentode.
Very nice curves, quite subtle shelving centre flat. Hifi style.
The gain across that eq+GCA+CF is more or less unity and can take very hot input signals from the Orange86. Easily up to 38Vpp that it can put out. The nfb part of the eq reduces this way down at the grid of the GCA. I have a 'Pre' pot on the end of the GCA+CF.
This EQ section picks up some nice GCA+CF warmth along the way too! That feeds the pentode like in Bernd's Rude Tube. And all is still well and quiet noise wize
On the 6as6, I have my operating point pretty much sorted, the CV works fine, the pentode mode gain is x90 or so and the triode mode is around 22 or so. I am adding the variable morph to my mode switch : a lorlin switch (Mode) and a pot (Morph).
The CV is done like this : I have a regulated +12/-17V from the Poorman PSU board I'm using in this channel strip.
I feed them to the ends of a 100K pot and take the centre as my CV. I add resistors on each end to match the travel of the pot at the extremes to around -7Vdc to +10vdc. I feed that CV into g3 of the pentode.
So this is the 'Drive' knob.
Have a 2K pot on the pentode cathode with a resistor in series to allow me to vary the cathode bias from +6Vdc to +0.5Vdc. So this is the 'Bias' knob.
Now the pentode output is ac coupled to a WCF. I may need to change that because I need some control before the wcf. Can't really put a pot to ground there. Don't want to use global nfb as it would defeat the purpose.
In fact I may not need a 'post' pot, as this is what the bias+drive basically does. Kind of.
Still to finalise that bit.
I like the step down with the 6n5p wcf with 15K:600 edcor output of the eq+drive module. Using 220V B+ with 1.5K on the plate, 220R on the kathode and in between tubes. Have 100V in between tubes and +2V or so on the lower kathode. Should be balanced pp for a 15k load. More or less.
Still have the option to elevate heaters (all the heaters are dc floating and not referenced to ground)
Right - my first problem is I'm seeing some low-freq rollof in triode mode, and additional hifreq roll off in pentode mode of the 6as6. It's independant of level and occurs at the output of the pentode and before the wcf. Taking just the pentode out of circuit and all is flat as.
Still to figure that out too. I thought pentodes didn't have a lot of miller capacitance so it should be something else?
And so making great progress. Should be buttoning it up in a week or two. Just need to sort out those things and do the remaining integration and testing.
The rude tube part is really interesting. The CV acts like a 'gain moodulator'. It only does something when the 6as6 is set up for high gain.
In triode mode is does very little (to level - not neccessarily to harmonic structure : still to check that out).
In pentode mode, if the tube is biased for strong gain, the CV is just like a volume control.
It varies the harmonic structure a lot - obviously, as it is varying the degree of drive going on in the tube.
Still making observations, but in sound it is like a volume control or as a distortion control if you are pushing it already.
So in use, one has the mode to fool with and then the degree of drive. The 6as6 can be fed with anything from 0 to 40Vpp.
Using the 'Pre' knob starts the drive ball rolling and the 'Post' knob is just a master volume.
The crunchiness is dialled in using the bias and drive controls. And maybe the 'morph' too! ;D
Now the CV knob can be somewhat irregular in control depending on where it is. There's a kink around -3Vdc or so.
Before that, the pentode is kind of starved and bedraggled. Very distorty and kind of thin. It goes down all the way to shutting off the tube practically. Above the kink, it's pretty smooth to +2V or so. On to 10V and it increases the gain, but less so as you get closer to +10Vdc. So the action is kind of -3V to +2V but is usable all the way to +10V for the max gain condition.
So the CV probably needs some smoothing. Could be some kind of r-c or evn r-l-c like Bernd!
Not sure yet. Right now it does what I expect from the data sheets more or less.
What Bernd seems to be doing is linking it to the kathode bias with interesting filtering.
And that's where I'll be soon. Trying some things out and seeing what it's like.
I'm also planning on some simple hpf and lpf at the end of the pentode.
Have to say, this monster has been a fine learning experience. I went from never a pentode to listening to the subtlties of pentode screen, suppressor and plate biasing! Not to mention baxandall eq'ing all on top of a Poorman 660.
This has combined at least four of my favourite things!
Cheers and thanks for reading that rambling lot.
