Very very nice post Dave. :thumb: I may say that your posts on recording tips have been very enlighetening.
I don´t have all your experience, I´m in fact just starting to explore, but I do agree that diferent preamps with different transformers put the tracks in a diferent "place" in the mix. And I also agree that transformerless recorded material sits on top of transformer coupled recorded material. I also may note that tube preamps that I´ve used, like the Langevin 5116B and the Pultec MB1, both originals and DIY version, so with diferent transformers, all seems to put the material more in the "center", more "compact", like it´s coming from one point only and discreet mic preamps, like NEVE, API, neumann, etc, all seems to put the sound more in the back or "from the sides", "away" coming from a "distant point". And transformerless designs all seems to put the sound in "front", comming from "nowhere", or "all over the place"....
Interesting to note is that I do think the active circuit has more to do with this than the transformers itself. Like, I have a tube preamp with an OEP transformer input, and I also have some discreet preamps with a OEP transformers wired the same way, and the tube preamps puts the tracks in a complete diferent place compared to the discreet ones. I may note however that the output transformers are not the same in the discreet designs and the tube designs... Still, tube pres tends to put the sound in a similar places to eachother (comming from the center, compact) regardless of diferent transformers, and discreet designs also tends to put the sound in a similar places (comming from the back, wide), regardless of using very diferent transformers, and actually "sounding" very different to each other. I mean a tube mic pre may sound very dark, and another tube mic pre may sound very bright, but the track still comes from a similar place "in the center" on both preamps. Am I getting too complex? :?
Have anyone experienced the same thing with tubes vs discreet experiments?
I´m not very much into FET preamps yet, but I´ll start to DIY some to compare to tubed and BJT pres.
Using all your gear together in an inteligent way to get your final track to sound good, with depth and space, rather than just recording each track with what you think sounds cool in that track alone, is the real chalenge. I always found that recording all sources with the same preamp makes a little more mess in he mixing process, regardless of this being a great preamp. In the recording process, you may find that all sources sounds better in a particularly killer preamp, but you would rather use other preamps that doesn´t aparently sounds as good as the killer one, but that will inprint another "place" in the tracks. It really makes mixing way easier and way interesting. So, I do think having a pallete of mic preamps and knowing "where" they "put" the sound in the mix is a very good thing to do.
I know it´s all very subjective and maybe I may sound even superficial to most of you, but that´s what I´ve found in my recent listening sessions on three studios that I have been working on, and with big colections of diferent and very nice mics. The strange thing is that the "space" perception of diferent preamps doesn´t change too much regardless of very diferent rooms, mics, power amps, and monitors. Each type of preamps still puts the sound in a particular "place". :shock:
