> what kind of output levels do you expect from your B&K's?
I figure AKG 414s can make 0.5V in front of an orchestra, fourth-row, and I don't think that is too far wrong.
Some mikes are hotter, and some situations call for putting the mikes closer. I think 3V is a possible level without even considering close-miked percussion and hot guitar amps.
At some point you do have to cry "enough!" and use a pad. And if the input noise is lower than 150Ω source, with big condensers a 10dB pad is no-problem (their self-noise runs 1uV).
Dynamics (and some SD condensers) in similar situations will top out around 100mV and have noise like a 100-200Ω resistor.
I figger full orchestra in the house as about 126dB SPL. That number was derived in the 1930s, confirmed many times, and my observations agree. Actually I can go a whole year without exceeding 118dB SPL, but you never know when the composer and conductor will pull every stop and belt a big chord with every lung and elbow working maximum.
A concert with noise near 14dB SPL and a peak at 126dB SPL, 112dB dynamic range, can't be played back verbatim in any normal listening system. Either we let the ambient and mike noise lay below media and playback-room noise, or we discretely trim a few notes. But the mike-amp should capture that 112dB and leave the trimming to post-production.
In less-loud situations: on women's choir, 2nd row, some Nak condensers slightly hotter than typical dynamics, 54dB gain into a 2V recorder just blipped the 0dB LED, so peak input was around 4mV.
Harpsichord in the big room, 4th-row (really too far back), AKG414, with 40dB-42dB gain, barely touched the -20dBfs lights at 2Vfs, so that works out to 2mV. Knowing AKG414 sensitivity, 80dB SPL at the mike. However the meters bobbled even when the harpsichord wasn't playing: sub-sonic rumble. So the actual musical level may be closer to 74-76dB SPL.
Note of course that if room rumble is near musical level, we ain't gonna get a high S/N no matter how we polish the amplifier. This room has problems; in a room suited to harpsichord we might get 74dB-14dB= 60dB S/N.
In the same situation, dynamics would have peaked maybe 0.3mV, and some ribbons (especially 37Ω types) closer to 0.1mV. Now we will have to polish transistors to preserve the acoustic S/N.
