pstamler
[quote author="chrissugar"]If the Gordon is done with only two stages I can only think that probably that was the best compromise and that is the way to go. I supose two stages is the best balance between noise, distortion and change in sound.[/quote]
It's worked for me, anyway. Well, sort of. In the solid state pre designs, which were really intended to feed unbalanced -10dBV outputs, first stage had 24dB gain, second had 26 or 28dB gain depending on which one you looked at. The balanced output stage was separate, and of course added 12dB.
The tubed design had only two stages: ~39dB for the first stage, ~20dB for the second stage (if present). Add transformer for balanced out. Because the input stage had relatively high gain (no global feedback), I kept a bunch of inline pads in the suitcase.
Which brings up a point: I've been allergic to any kind of switching in a mic input ever since I almost got fired when an A/B switch on our (old) console at channel 9 went on the fritz during the fund-raising auction. The director cued me, I brought up the fader on the channel with the KM-84, the floor guy cued the string quartet, and -- dead silence. After several seconds of panic, we cut to a videotape. While that was on, just as a hunch, I worked the A/B pushbutton switches back and forth a couple of times. The signal came back. Explaining to the operations director was an experience I wouldn't want to repeat.
So I use inline pads now rather than switchable pads. If our design includes any switching, particularly in vulnerable low-level spots, it should be done by switches of irreproachable quality.
Peace,
Paul
Peace,
Paul
