Transfer Console build
Your soldering work looks very good. I didn’t mean to scare you. You could always check it with a pot first. Anything from 1K to about 50k linear would be fine to check functionality.
Thought I’d post an update…
I’ve finished wiring the power and audio, will do some testing before moving on to the switching. Using the DIN rail has made a big difference, and I now have 2 new favourite words: crimper and ferrule!
The chassis work is pretty rough, but it’ll get get the job done. I’m planning to use a temporary front panel while I work out the final layout.
The monitoring section will change, but for now I’ve got 3 switchable sources - a mult from the main outs, a mult from the IGFO output and an external L/R via XLR. This last option will give some flexibilty, my first idea is to monitor the DAW input post-preamp, pre-A/D.
cheers
Stephen
I’m happy to say this is now finished. It’s changed a lot since my last post, and I’m really happy with how it’s finished up.
There is absolutely no way I could have done this without Wayne Kirkwood’s help, his support has been exceptional.
It sounds fantastic.
Stephen
    3.7 MB
    2 MB
    1.7 MB
    2 MB
