Loved the war sketch ;D
Hmm yes indeed the Carnhill inductors carry a premium price tag for what is esentially ,I think, a randomly wound bobbin with taps at set intervals , I see pot cores of various descriptions are available quite cheaply ,but all too often the full mounting and and clamping hardware isnt included . I did find half a dozen or so proper pot cores of the same type used by carnhill and others who made neves inductors along the way , the usual brown bakelite board with pins and the metal clips to hold the cores shut .
Im just in the process of making myself up a winder specifically for smaller fine wire coils , stuff like pickup coils , eq inductors and maybe small signal transformers too , just a really simple arrangement , an old cordless drill motor ,gear box and chuck , then on the other side mini Veeder root counter coupled through a suitable coil former mount .
I got a neat little dc speed controler off ebay , its just the usual pwm type thing ,but its has a control panel where motor parameters like accel/decel , rpm , and speed stepping can be accesed , I might just use a 12volt sealed lead acid with a solar panel for juice . I think a simple guide bar for the wire with adjustable ends stops to prevent wire spilling over the edge of the bobbin will suffice here , I did also get some ceramic pulleys for light gauge wire and I have other odd rollers bearings and shafts , so Id like to figure out some kind of tension adjustment .
The sections in 'coil winding second edition' relating to the machines for various kinds of winding ,the gearing cogs and cams was a really great , even though the cam mechanisms now probably a thing of the past it serves as a great way to understand the physics of various winding methodologies .
