this is just a Public Service message on a quick and dirty way to screen transistors if you are replacing, say, 20 of them onto a carvin b1500 or some other heat box,
you just take some readings on what base current sets up what collector current at a fixed voltage across the emitter and collector,
this can make the transistors last longer by even load sharing, and it is fun!
use a heat sink otherwise the collector current will creep up as the transistor warms up,
you will need a dual pwr supply, or a single supply with a pot if you are clever,
this bench looks like this (also does mosfets at top of test jig)>
