hello again people,
I am just updating this post a little
I left out some helpful info at the end
just wanted to add more info about my grill work ok?
one thing i did that was recomended in another post regarding the soldering of the screen material...
I had a tube of extremely similar proportions so i inserted and piece of grill material inside the tube and trimmed an re-fit it until it matched perfectly with ...no overlap ...of the screen...
I then re-inserted it and let just the smallest bit of material extend past the end othe tube.
this holds the material in place quite nicely. (great suggestion whover posted this originally)
i then tacked the edge with a few drops of solder
then I removed the material ...flipped it to the other side and positioned as described above and tacked the other side with a few drops of solder
OK now we have screen cut to exact proportion and tacked at the seam on the 2 ends.
after this i slipped the screen a out a little more and continued to solder about half way then i flipped it again and did the other side..
I must mention be careful that your solder or flux doesn't drip onto your screen anywhere...the flux is easily removed but un-necessary if you are careful. a solder drip could be horribly disasterous if you want everything really pretty..
i leaned the tube and screen at different angles to prevent drips and encourage the proper flow of the solder..
ok now we have a soldered screen ... shaped like a tube with a single seam.
this seam proved to be a bit of a problem for flush placement within the mic body because of a few solder "bumps" so.....
after dry fitting it into the mic i removed it and simply sanded the soft lead solder until it was nice and straigh and it fit tightly..and evenly right up against the inside wall of the mic body. the grill screen is not soldered to the mic body...it fits tight inside and doesnt move..this makes the grill removabe and replaceable as well as modify-able (like painting it black or someithing) i think this was a better altenative to soldering "inside the mic body" even though it was a bit tedious...if you try this out...i think you will be pleasantly suprised.
the top grill was super simple
cut a round peice of material ... pressed it over an asprin bottle and just inserted it after forming....my mic body is threaded at the top so a trim ring will complete the top ring installation and make it pretty/
one thing..the asprin bottle had an indention in the bottom which helped to definge the edges when the middle of the screen was pressed into the indention on the bottom of the asprin bottle while holding the edges firmly.
i hope this info was helpful to someone
and OK BTW ther are some questions in this post that remained un-answered mysteries...I will condense them for discusion at a later date and continue to search for the answers. (to post)
In the mean time if anyone can answer a question not already answered here please ...please... please... feel free...:
ush push:: ::nudge nudge::haha
this mic will be on the back burner for a while untill I can get the neos I plan to use to boost my flux.
Until then I have started a new mic based on the RCA 74b. look for this new topic soon...tomorrow maybe.... when I can get the pics out of my daughters digital camera......
she hogs the camera alll the time hahahaha
but hey she can have anything she wants...and that's why I have nothing...ok not really nothing but.....arggg....
I'll update this post when I have the results I am looking for. ( or if all efforts fail...which I don't expect considering my output wasn't too bad) I may try some differnt trafo ratio's too. (funds permitting)
anyway bye for now
enjoy life
ts
