Hey everyone, many thanks for all your advice.
After doing a bit more noodling around and learning about CCS, I think that I may be able to get enough gain using two 6021 stages with a CCS as the anode load for each stage. A CCS anode load can bring the gain up to nearly the mu of the valve, and with a mu of 35 two 6021 stages would provide 60dB of voltage gain. 30dB per stage, 60dB gain overall, 20dB loss for the passive RIAA leaves the target 40dB.
The advantage of the 6021 vs the 6948 (aka 6112) is the higher gm of 5.4mA/V and lower anode resistance of 6k5 ohms. This should mean lower noise from the stage itself and also lower resistor values for the RIAA network. If I parallel up two triodes for the input stage, I should get a anode resistance of around 3k3 so I could use a 33k build out resistor for the RIAA network.
Given that I now don't believe I can implement a differential tube amplifier stage that has BOTH perfect balance from the CCS in the cathode, and maximum linearity and gain from a CCS as the anode load, I think I will stick with a single-ended design for now.
Operating point wise, the most linear part of the 6021 I can find on the curves is 5ma with 2v bias, 123v on the anode, 0.62W dissipation (88%). If I use a 250v supply that would make 123v on the anode half the supply voltage which is handy for a DC coupled cathode follower. I will use the same operating point for each stage.
I get different absolute max values for Va on different datasheets, I have the standard GE non-WA 6021 which quotes 160v as the design maximum but in the tables they give examples using a 225v supply so will I be ok with 250v at turn-on?
1. Parallel 6021 triodes with a cascoded mosfet CCS (perhaps DN2540?) anode load. per triode: V supply 250v, 5mA, 2v bias, Va 123v Pa 0.62W (88%). LED bias. mu = 35 = 31dB; Rp = 6k5/2 = 3k3
2. RIAA network starting with 33k series resistor, other values calculated using http://www.mh-audio.nl/Calculators/CalculateRIAA.html
2. 6021 common cathode gain stage with cascoded mosfet CCS anode load : Vsupply 250v, 5mA, 2v LED bias, Va 123v Pa 0.62W (88%)
4. 6021 DC-coupled cathode follower: Vsupply = Va = 250v, Vg 123v, 5mA, CCS cathode load, arc protection.
Many thanks
Many thanks
