I'm having the following problem. Here's the input mic preamp stage (this is the part of the V76 circuit verbatim):
For some reason I get the HF roll-off that starts around 6-8K, gets to the -5dB point at 10k, and -10dB at 20k. I'm sure this happens around the very first tube since I measured the output at the marked point and the roll-off is there.
I'm running this circuit in a simulator and I cant get any roll-off no matter what parasitics I include in the sim.
Interestingly, when I go into the tube directly (omitting the input transformer), the HF response is flat. This leads me to the thought that something is funky in the impedance department between the input transformer and the tube input impedance. I tried various sources, but could not get rid of this roll-off. This roll-off gets worse if I connect the input windings in parallel.
What could be causing this issue?
