You probably mean dBu...I'm doing measurements once again.
Test signal unloaded output is -45dBm.
When connected to the transformer it reads -48dBm
That is not normal. Are you sure the G2 is properly by-passed?Transformer output is -20dBm unloaded and -23dBm when connected to the tube.
No, it doesn't. It measures at -50dBmDoes the test signal still measure -48dBm with secondary connected to the tube?
Probably. This is how my HP34401 shows.You probably mean dBu
Primaries are 370 mH each, Secondary is 1970H. I don't know the test voltage, sorry.Out of curiosity and assuming you have an LCR meter at hand, what is the inductance of pri and sec at 100Hz (at 1V preferably)?
I'm using 806s and I did ground screens.Are you using EF804 tubes? And have you grounded the screen pins?
Do you mean the 50n cap at position 14? Yes, I do have it installed.That is not normal. Are you sure the G2 is properly by-passed?
Sorry, missed this one. Yes, it's a sound card.What is the signal generator? Is it a line output on your audio interface/soundcard?
Actually, I do have the -20dB pad built into the front end (it's 2x866R series resistors + 200R shunt) and -30dB pad (2x3.16K resistors + 200R shunt). HF roll-off is even worse with either of these pads engaged.I would use a 20dB mic pad (could also use a 40-50dB line pad) between the generator and the primary
Hmm ok, well this certainly tells me that adding series resistance (2x866R) to the load degrades the HF response further. And if the intention is to use this preamp with microphones and sometimes with these pads engaged, then a lot of mics will have issues in driving this setup.Actually, I do have the -20dB pad built into the front end (it's 2x866R series resistors + 200R shunt) and -30dB pad (2x3.16K resistors + 200R shunt). HF roll-off is even worse with either of these pads engaged.
If the issue is that the source impedance of the soundcard is not low enough then I don't think this will get away from the issue, and may actually make it worse, as Ilya seems to have already observed.OK, the generator has significant loading effects. May or may not indicate an error.
I would use a 20dB mic pad (could also use a 40-50dB line pad) between the generator and the primary so as to raise the load Z on the generator, remove any loading effects. Raise generator output accordingly.
OK. RME FireFace 400 states 75 ohm output. 6K pad resistance, hard to believe that would be a problem.Sorry, missed this one. Yes, it's a sound card.
Well, it shows that connecting the tube's grid to the secondary loads it significantly, which is not normal, since the low-frequency input impedance of a tube is supposed to be almost infinite.No, it doesn't. It measures at -50dBm
Have you noticed that the EF804 has a different pin-out than the 806 (or 86)?I'm using 806s and I did ground screens.
Yes, I've accounted for the pin-out difference.Have you noticed that the EF804 has a different pin-out than the 806 (or 86)?
I didn't have any mic input triads, but I have UTC O-12 that can be configured as 50:500 step-up. Better, than nothing.
With O12 the frequency response is nice and flat no matter what I do with the front end pads. The level is obviously quite low, so I'm now more confident in my theory that it's the Sowter that is acting funky.
I don't see how it would be the case here, since the open-loop input impedance is supposed to be infinite. NFB could not change it.Some preamps vary with gain setting, such as the RCA op6. The v76 might also, due to a similar variable neg feedback path
Will check this, but frankly, I doubt that this will change anything much.You could try lifting that screen from GND and then test
I'll try that, Should be fairly simple to do - replace 200R with 50R and leave 3K16 in place. Should be good enough for testsYou could try making a pad with a couple of 3K3 resistors and a 47 ohm shunt
This is an all new build, tube sockets are new as well. I'm pretty confident regarding the build and the exact circuit I'm using. I've checked it probably hundred times (I know that there's still room for error, but the chance is rather small). Is there any way to test for this impedance problem? As far as I can tell now, it's the impedance mismatch between the reflected impedance to the secondary and input grid impedance.It seems though that the impedance is not infinite, for a reason I fail to grab. Maybe a roasted tube socket?
It is obvious that Sowter did cut some corners. The V76 input xfmr is deemed impossible to reproduce, because of the lost art of multi-chamber winding, segmenting and sandwiching.Yes it could well be Ian, but Sowter offer this as a replacement for a v76 input trafo, and the v76 has an input impedance of 200 ohms I think. Looking at Ilya's inductance measurements at 100Hz (370mH each pri/1970H sec) then with primaries in series this will theoretically be 1.48H total, which then not considering the load on the secondary, this L presents an impedance of 465 ohms at 50Hz, or 232.5 ohms at 25Hz. To me this is Sowter cutting it as close as they can for a 200 ohm input Z and minimal secondary loading. With such a high ratio maybe they needed to so that the secondary wasn't a million turns.
