- Joined
- Mar 11, 2014
- Messages
- 249
Hello, my name is Tomas and I'm from Malmö, Sweden. Although I've been repairing, modifying and building studio gear for a couple of years this is my first post in a forum. I primarily service microphones and I'm currently working on restoring a vintage U47. When I got it most of the interior hardware were missing and a hole was drilled through the back of the body. After some research I found the answer in a picture on the fantastic page filmsoundsweden (only in swedish) that showed a U47 modified in 1981 to a custom FET circuit by a Swedish company (AVOX).
Fortunately the custom flat 1780 ohm wirewound resistor (R4) that drops the voltage to the filament was still there but the connection was bad on one side. I actually managed to fix this by wiring it back one turn, scrape of the outer coating and resolder it. Now to my specific questions:
1. Does anybody know what material you can use if you want to wire one of these resistors yourself? My own research ended up with enamel coated nichrome wire. What material can you use for the flat core? Remember this resistor gets very hot during operation.
2. These resistors are surrounded by some kind of oil, which I assume is to increase the contact with the microphone body to cool the resistor. Does anyone have any knowledge regarding this? Is it possible to use the standard white thermal grease?
