mrcase said:how high should the capsule be fitted?
I have a thiersch and a beezneez capsule. should I use either with the plastic plate or without?
if I use the plastic plate the membrane is partly behind the upper ring of the basket. (dunno how to explain that better...)
Is it supposed to be like that?
If you look at a U47, the capsule is partly behind the upper ring of the headbasket. I mounted my Beesneez capsule on the plate and it sits just like this.
Paul
