The value of these resistors is almost irrelevant. You don't need to change the value of capacitors.I welcome everyone.
I do not have the values of resistors R5.R6 - 100M, but there are 200M.
If they are used in this circuit 200M, then I also need to increase the value of the capacitors C4 / C5 to 20n?
The role of this combination of resistors and capacitors is to filter out any residual noise on the bias voltage. This noise is a combination of AC mains frequency residues (100/120Hz and harmonics) and some low level wide band noise.Just for an example: in the Sony c800g circuit the capsule voltage divider, these are small resistor values and large capacitor values.
In the circuits of most other microphones, on the contrary, these are large resistor values and small capacitor values.
I thought that an accurate calculation of these values is needed here.
Your 100uF capacitor would probably be an electrolytic, innit?So the combination of 10K and 100uF will be the same?
It's clear, but I'm looking at the s800g circuit, and it works fine ..Your 100uF capacitor would probably be an electrolytic, innit?
You have to know that 'lytic capacitors have a much higher leakage current thna film or even ceramic caps. This leakage current can surely load the voltage multiplier, and result in a loss of bias voltage.
What's more, leakage tends to increase with age.
So I would not recommend this combonation.
I haven't tested this yet, but could there be a difference in case of capsule overload, hard plosives and or moisture from breath (k67). Recovery wise. @abbey road d enfer @RuudNLThe role of this combination of resistors and capacitors is to filter out any residual noise on the bias voltage. This noise is a combination of AC mains frequency residues (100/120Hz and harmonics) and some low level wide band noise.
The typical combination of 100Meg and 10nF gives an attenuation of 50dB at 50 Hz, which is largely enough if the PSU is half-decent.
A combo of 1 Megohm and 1uF would give the same result.
Nothing very complicated here.
The lower the resistor values there, the less they are sensitive to overload effects.I haven't tested this yet, but could there be a difference in case of capsule overload, hard plosives and or moisture from breath (k67). Recovery wise. @abbey road d enfer @RuudNL
The amount of HF negative feedback is directly proportional to the value of this resistor, so if you increase it it decreases treble.I have a question about the R1 10K resistor.
If you increase or decrease its value, how can this affect the operation of the feedback filter?
I did not conduct such tests, this is on a subjective level .. It's just that 47v on the capsule did not seem as sharp as 60v.Try to place the microphone at exact same position, preferably not move it at all. Record same exact sound source with two different pol.voltages. I play pink noise and some music through monitor or raw guitar tracks through a cab. Then blind shootout the files, do null test with both recorded files.
My experiments show the files cancel out perfectly at these voltage ranges ->exactly the same. Noise and max spl of course differ. The catch is not to change anything besides pol.voltage. i don't even breathe, nor move during the test. Go frim lower to higher voltage.
Just for fun, I recently put together a "U67"-ish microphone.
It is a kind of mix between a U67 and a U87.
The microphone works as expected, sounds good and I don't hear any difference between this microphone and a U87ai.
Measured self noise is 2 dB higher than a U87ai. Not too bad, but maybe a better EF86/EF806 could improve this.
I used an original Neumann capsule that I had as a spare.
The microphone is powered from an existing tube power supply, delivering +120 V for HT.
De-emphasis is through feedback from the output. (15 KHz is 5.5 dB down referred to 1 KHz.)
For those who are interested: the schematic is in the attachment.
