RuudNL
I suppose this will work. You may want to adjust the value of the 120 pF capacitor, depending on the capsule you use. (I have also used 100 pF and 150 pF. Higher value = less HF.)
I have built several microphones like this, but never had this problem.I have tried your U67ish de-emphasis in a similar mic circuit but if I connect the 120pf after the output capacitor I get noise (probably from B+ because if I turn off the psu, the noise dissapears).
Maybe, have no idea how it work and how to get rid of it. It starts after some seconds. Even with a very small resistor of 40ohms the problem seems to solveI have built several microphones like this, but never had this problem.
For AC, the signal at both sides of the output coupling capacitor should be (nearly) the same.
Isn't it oscillation?
Thanks. I'll try and report.I suppose this will work. You may want to adjust the value of the 120 pF capacitor, depending on the capsule you use. (I have also used 100 pF and 150 pF. Higher value = less HF.)
Hi RuudIf anyone wants to try my design: I have a few extra printed circuit boards available.
(The PCBs fit into Chunger's 'budget' SYT-5 body.)
Edit June 07: All PCBs found a new owner...
At the moment I don't have PCBs available, but I will try to 'dig up' the design, so you can copy it.Can i try your design PCB?
Hello!At the moment I don't have PCBs available, but I will try to 'dig up' the design, so you can copy it.
For sending a PM (Personal Message), just left-click on the member's picture/avatar and then pick "Start conversation".Hello!
I did not find how to write to you in a personal.
Thank you. I understand.For sending a PM (Personal Message), just left-click on the member's picture/avatar and then pick "Start conversation".
yes sir, looking forward to itAt the moment I don't have PCBs available, but I will try to 'dig up' the design, so you can copy it.
Just posted my upcoming project Tube microphone project with vintage M7 capsules after RuudNL using your schematic RuudNL and would be grateful for comments and if anyone has a parts list to share.Just for fun, I recently put together a "U67"-ish microphone.
It is a kind of mix between a U67 and a U87.
The microphone works as expected, sounds good and I don't hear any difference between this microphone and a U87ai.
Measured self noise is 2 dB higher than a U87ai. Not too bad, but maybe a better EF86/EF806 could improve this.
I used an original Neumann capsule that I had as a spare.
The microphone is powered from an existing tube power supply, delivering +120 V for HT.
De-emphasis is through feedback from the output. (15 KHz is 5.5 dB down referred to 1 KHz.)
For those who are interested: the schematic is in the attachment.
HiHi.
I think this is a great project.
I'm going to build this with a body without switches on it so I'm thinking to use REMOTE PATTERN from PSU.
I modded schematic. I don't know if it's ok.
I'd like to build it but I'd like to remove FILTER and PAD, too.
Could it work like this scheme attached?
To test it without feedback (to hear Flat capsule response) can I only wait to install C9 or with this pattern arrangment C5 need to be grounded to work without C9 installed?
Just ordered some stuff and here is my parts list Parts listJust posted my upcoming project Tube microphone project with vintage M7 capsules after RuudNL using your schematic RuudNL and would be grateful for comments and if anyone has a parts list to share.
Robert
The more microphones I build, the more I come to the conclusion that point-to-point, Turet... is a lot less trouble than building with etched circuit boards.....CheersI improved my layout in the second one (bottom one), moving R1 to the switch PCB, as in the original diagram. Now no "crossed wires" on the backside!View attachment 118567View attachment 118569
...until you have to replace a part that has a leg that forms a bus. Desoldering gets messy fast. I'm a fan of PCBs myself.The more microphones I build, the more I come to the conclusion that point-to-point, Turet... is a lot less trouble than building with etched circuit boards.....Cheers![]()
