I know this topic has been probably beaten to death but I still have a question about unbalanced outputs to balanced inputs (ie: old 4 track R2R tape machine (RCA) to balanced patchbay (TRS)). I understand that transformer isolation is the recommended method to connect such devices, something like the ART T-8 would work. I also understand going balanced output to unbalanced input is fine to connect tip to tip and shield to shield as it essentially just makes an unbalanced connection. My question is why does the RANE interconnection document recommend tip to tip, and shield on the RCA to the ring on the TRS? Just interested to know how the balanced input circuit reacts and why you wouldn't connect the shield to shield and leave the ring disconnected. See #18 on the attached document and the "last resort" method.
The tape machine output would most likely be connected (through the patchbay) to a balanced line in or mic input on an A&H mixer (transformerless) or CAPI VP28 Mic/line preamps (transformer). Would this change the preferred way of wiring? Thanks for sharing your knowledge everyone.
Ryan
Ryan
