ruffrecords said:I have always found magnetics rather arcane with its terminology that I find hard to visualise. Ohms law is no problem. I can imagine current (electrons) flowing through a resistor and how much gets through depends on the constriction of the resistance and the force you push it with (voltage). What are the magnetic equivalents?
I guess you know, but the magnetic flux could be seen as a current, and the permeability as the conductivity, so is pretty much the same thing, in the middle you change from one type to the other, you change from electric to magnetic and then electric again, but you could think as a third electric path, non linear, but we are used to non linearities as well with semiconductors and the absorption in capacitors, just thinking in the magnetic flux as a third electric path could help. The only difference is that you don't have a particle moving around caring the energy (usually the electrons), but the movement of those electrons make the magnetic flux. The easiest maybe is think as an abstract way of electric flux with different rules, taking into account the absorption and non linearities of the core material, the other losses by joule effect are part of the usual electric path (as the winding resistance) which should be no problem to you, used to work with those all the time, as you said, ohms law.
JS
