Volume11
Do you have more syt-5 bodies arriving soon? I just started ordering parts for another d67
Volume11 said:Do you have more syt-5 bodies arriving soon? I just started ordering parts for another d67
chunger said:Per requests here, I am changing specs on the new bodies. . . the GT-2B and SYT-5 use a M26 thread base for the bottom cap as well as shockmount. The new factory I'm dealing with standardizes on M24 for the bottom of their mics. I'm working on getting specs for my mics changed to M26 to be backwards compatible and use a single threaded shock mount. Depending on how difficult the change will be, I may end up still going to the smaller M24 threaded base.
Shifts like this eat into development time, but I'd rather get all the details right the first time around even if it will be a bit longer lead time for the 1st production run.
My factory contact informs me that we are close to having prototypes to verify compatibility with all existing kits.
Can you describe some of the changes/difference you're designing with the factory? Maybe turning the SYT-5 into a 3-layer? Making the GT-2B closer to a U47? I bought a Beesneez K7 in anticipation of building a D-U47fet, but looks like I wont be able to get a body from you until the new batch...chunger said:The wheels are turning very quickly behind the scenes right now. I will post pertinent milestone developments here as they come as well as updated timeframes for delivery. The plan was originally to do all of this while the 1st batch of microphones was comfortably in stock, but interest has been quite a few notches higher than expected.
No need to "cobble" together bodies for various projects. Once I get a smooth workflow going with the metal factory, development liaison, and Q/C representative on the factory floor in China, I should be able to start from clean sheet and do proper justice to projects like poctop's M49, but there are already developments along those lines state-side. If those pan out, it may not be necessary to expend the effort in that direction.
For right now, I'm hoping the next batch of mics will carry improvements all around, and I hope to turn my attention towards a km84 project in collaboration with Matador that will involve a "clean-sheet" new body.
dmp said:Any chance that you could do another order exactly like the first, while you are developing this redesign?
The GT-2B and SYT-5 particularly, as they seem to be in high demand.
Since we're getting the pcb sets from Poctop and eager to build mics!
That's good news, too.I was never happy with the price-point of the SYT-5 and GT-2B on the first shipment of microphones, and I intend to improve on that.
micaddict said:Looks promising, chunger.
And good things take time. I believe it's a good decision to get it right first.
FWIW, someone on the the Gearslutz forum quoted $88 for the GT-2B or HT-11A plus case, directly, if not bought in serious bulk. Don't know if that makes sense.
Dylan W said:If the new SYT-5 headbaskets will be vintage-correct 3 layer mesh, will they be compatible with the first round SYT-5 bodies? And would you consider ordering a small quantity of extra headbaskets for those of us who already have one?
JessJackson said:hi, how can i order the three switches and the 3 pin XLR insert?
chunger said:Volume11 said:Do you have more syt-5 bodies arriving soon? I just started ordering parts for another d67
No, modifications to the design are being finalized and I will need to confirm all kits are compatible with the body before production run can begin. This will take some time. I was hoping stock of SYT-5 bodies would hold out longer to allow for continuous supply during this development cycle, but unfortunately, I have run out of stock on the original batch. There is a chance some B-stock may be available, but these are being held for the time being for a few kit developers.
We just made another change to the design today which will delay the prototype again. 2 months would be the earliest I can see bodies being back in stock. I am, however ordering greater quantities this time, so they should remain in stock longer. Pricing should also move in a favorable direction.
Toure14 said:Chunger I just purchased my SYT-5 body recently and have not begun my U87 build because I'm still waiting on my Hakko FX888D to arrive. With that being said, should I continue with the soon to be "generation 1" body? will I be missing out on any major or substantial elements to make this an easier or more efficient build? any improvements to sound quality due to the new head basket? If so can I return my body I just purchased at this point since it is brand new and unused?
Also, after combing thru your u87 photo build which will be a big help I have a couple questions in regards to parts for the build. You used some hardware that you mentioned wasn't quite proper to connect the switch pcb, what would be the proper hardware and sizes? You used some brass bar to mount your transformer to the body. Do you supply that piece? If not what specific type of brass bar and what hardware store?
Last, you used a 6mm height screw to raise the height of capsule which actually made the mic look more authentic and for my application (which is vocals) should sound better based on mic positioning, where did you source that piece?
I should mention that I went to Home depot and showed the pics of the hardware but everyone looked at me strange and said that they only carried regular size hardware...So this is why I am asking for the source of your parts not included in the kit
chunger said:dmp said:Any chance that you could do another order exactly like the first, while you are developing this redesign?
No, the minimum order quantity from original factory for SYT-5 is 100 units and 50 units for the GT-2B, and inside the development/production cycle for the same style bodies, I simply do not have enough liquid capital to purchase an interim shipment. Also, there will likely be a SIGNIFICANT price decrease on the new bodies when they come in, so I would likely be stuck with a large inventory of microphones when the new ones come online or, I would simply have to delay rolling out the new bodies until the interim batch is sold. As it stands, if the factory is indeed close to finishing prototypes right now, there is only a few weeks time difference between ordering again just like the first shipment and moving to the new bodies.
I understand that many people are frustrated with delaying their projects, but I was never happy with the price-point of the SYT-5 and GT-2B on the first shipment of microphones, and I intend to improve on that.
The headbaskets will be 3 layer much closer to the vintage originals.
2 layer headbaskets for ELA M251 builds on the HT-11A have already been prototyped, confirmed, and the order placed for production at volume. Matador is working on doing a sample build of the ELA-type circuit right now on the current C12 pcb set.
