Category 5
Stellar work Chunger. The prototype is looking great and we can't wait to see the final product.
0dbfs said:Ordered two head-baskets. Thanks Chung!
jb
poolshark said:Great news about the prototypes coming in! Are there still too many variables at this time for an estimate on when the GT-2B's will be available to order?
chunger said:Yes, I received a prototype for the GT-2B gen 2 microphone and all of the existing pcb's fit the new body which is good, but the body was based on a 52mm diameter tube instead of the nominal 60mm tube for U47 type mics. The mistake was mine because in order to keep the final cost of the microphone low, I advised the factory to pay particular attention to the internal dimensions, rail configuration, and headbasket mesh. . . and use the path of least resistance for the rest.
So, the gen 2 GT-2B body is not as close to production as the SYT-5 gen 2 bodies. The good news is, the factory does have a 60mm body and we have already done the work to make the rail setup. I also included 2 more mount points in the rails at Poctop's request for mounting transformers, so this should work out well. I do apologize for the extended delay, but I think a better spec'd microphone at ~$60 per unit price reduction is worth it in the long run and should put some of these mic projects within reach and maybe allow folks to build multiple microphones when they could only build singles before.
jplebre said:Hi Chunger
what about the donor mics?
Cheers!
strangeandbouncy said:HI Chunger,
I am a very happy camper with my C12 Headbasket, but I am also very keen to try the 251-type too. DO you have an ETA for these?
KIndest regards
ANdyP
