Phrazemaster
That's very helpful, thank-you!tonzauber said:You need the following parts (with Neumann Part numbers)
062086 Capsule Holder ("Saddle")
066176 Schwinggummi (rubber part where the capsule Holder is fitted)
060023 (2x) Screw
060107 (2x) Spring washer
060585 Solder Lug
053291 K49 Capsule
I talked to Dennis at AMI; they have the whole capsule mount - plus stem, solder lug too, and it's historically correct. The Sennheiser is more expensive. If I wouldn't have talked to AMI already I would do as you are suggesting; thanks very much!!
Here's a link to the AMI mount system: http://www.tab-funkenwerk.com/id191.html
Mike
Edit: added link.
