I have a couple of Lorenz V241 preamps for service.
I measured all the resistors / capacitors and many need to be replaced.
In general, does the big oil capacitors need to be replaced over a 60 years period (like electrolytics) or can stay if measured good?
One of the 1uF oil caps (C4) needs to be replaced, which type of modern capacitor would be the right replacement for it?
Also I would like to replace all the 20uF/450V filter caps. Is it possible to find new capacitors with this type of screw / nut mounting arrangement (like the one in the picture) or should I remove the old ones and install terminal strips and new axial F&T's instead?
