Here's something that some of you might find interesting. Compressor that use 6V6 tubes as vari-gain tubes. 6L6 tubes work here just as well and matching tubes doesn't seem to be an issue. Most 6V6 and 6L6 tubes bought as a matched pair for guitar amps seem to easily give thumpless operation.
The principle is very simple just one variable gain stage and a sidechain amplifier, just like Fairchild 660.
Here's a simplified schematic. I'll post the full schematic after I've done last few tweaks.
Max output is 26 dBu to 600 ohm load with less than 1% THD, mostly 3rd harmonic. With over 10 dB of gain reduction the distortion figures aren't very impressive but that's already much more than most people need. Gain is 7dB to 600 ohm load and almost 14dB unloaded.
I stole the sidechain from here http://groupdiy.com/index.php?topic=11469.msg136132#msg136132 and made a couple minor changes.
Here's the compression curve with threshold at minimum.
Few pictures of the unit.
In the picture below you can see the toroidial 15k:600 output transformer that I ordered from Poland http://sklep.toroidy.pl/en_US/index
