clintrubber
[quote author="rodabod"][quote author="clintrubber"]
As I hope and am reasonably sure the situation is like this:
Connecting them in series gives you a centre tap to which you can or won't be connecting phantom by what was it, a 3k4 ? Ratio will then be 1:N.
By connecting them in parallel the ratio will be 1/2:N, so 1:2N (and the impedance-ratio will scale fourfold).
As I understand bifilar, it's just that two windings are wound at once, so they're kind of twins i.s.o. one after the other (with 9 months delay :wink: ). For the principal functioning of the TX it won't matter I figure.
[/quote]
Hi Peter,
Is having a bifilar twin primary the same as having a split primary?
[/quote]I think the former is always the latter, but the latter not necessarily always the former I think. The difference is in how they're wound.
As you stated it, from 'twin' & 'split' both follows that the primaries are not already connected. If they were the word 'centertapped' would have been used somewhere.
You likely will have had a look already at various possible permutations in the Beyer catalog (the 4th digit I thought).
So, will the ratio not just be the same if you parallel these bifilar primaries? The turns number on the primary would just be the same, no ?
[/quote]Nice explanation, understanding this. Yes, the ratio will stay the same, as CJ said.
But how about impedance ? May get confusing since some 'fixed' relationship between ratio (N) & impedance-scaling (N*N) seems to get broken:
For each doubling of the amount of parallel windings the impedance when looking into the whole thing halves, correct ?
Say you got a 1+1:N and a sec. termination of 100kOhm. Just using 1:N gives an impedance when looking into that one primary of 100k/(N*N).
Add the other primary in parallel to the first primary, we maintain the ratio, but now get 0.5*(100k/(N*N)), correct ?
Yes that was too funny, and that even in one posting. Sigh...
You're right, should be terminated.
[/quote]
Hi Peter,
I asked what would happen when paralleling a split primary (because I thought it would halve the ratio) but this is what CJ said:
[quote author="CJ The Transformer Murderer"]Imagine if you used 100 strand litz wire to wind a primary. How many turns do you have if you wrap the litz wire around the core one time?
1 turn. Even though that turn consists of 100 individual strands of wire.
So if you parallel a primary, you are just doubling the strands in your wire, not doubling the turns.
So the ratio stays the same.
[/quote]Of course, it is easy to double the ratio with the twin primary...
P.S, Peter, those puns are getting worse and worse....
[quote author="Peter The Comedian"]they're kind of twins i.s.o. one after the other (with 9 months delay :wink: )...
Please let us know how they turn(...) out !
