Vintage Tube & Vintage FET Microphone PCB Kit For DIY & New D7 Custom Capsule
Hi Poctop,
How did you choose the 0.32H choke for the 269 / 49 PSUs? I usually think of them being higher, 5-10H.
dmp said:
Hi Poctop,
1- Avaliability
2-Henry
2- DC current Max  : In General the higher inductance the lower DC Max, since i had in mind the psu to be solid with most tube configuration possible as
even for other mics some are more energy-Vorous  Heater current than others.
3- Footprints
4-Price
So basically  A trade-Off on all those things,
Be noted that the 500mH form this series will work fine , but at a cetain point filtering a already clean DC output Voltage is pointless.
dont forget the RC filetering Stage also Work well on this,
here is a quote from
http://prorecordingworkshop.lefora.com/topic/11780711/Chokes-in-Neumann-PSU
the choke is actually optional on the 2469 passive psu
you can replace it with a 10 ohm Resistor , I never had the time to actually try it with and without and compare on my list tough,
Hope this helps,
dAN,
shipped this morning , To USA and Australia,
Best,  :)
daN,
wave said:
Dany WILL take over the world!
maybe not  ;)
do i have to be worried of  Austin Powers now  ;) and mini-me.
;D ;D ;D
Hi Dan
Ordered 2 packs of u87 PCBs with correspondent styroflex's the 9th, got them today. Impressive!
dribro said:
Hi Dan
you are welcome, happy build,
BEst,
DAN
D-Elam 251E with True Pattern Switching on PSU , I had to terminate what I started,
this was a very fun build.  Specially the Point to Point HZ bridge,  half PCb/half PTP for the Optimal Results and Maximum Fun
Enjoy,
more Info soon,
I needed to get rid of a pair of stamping siders with the aid of a metal cutter and a file  :p
Best,  :)
DAN,
Ela M 251 stock out
Thanks ,
Dan,
Shipped today to US and Estonia  :)
DAn,
shipped to US today .,
BEst,  :)
dan,
Shipped to US today,
Best,  :)
Dan,
dD
D-47FET    3 Railing system (AMI-IOaudio) microphone body type.
  i am working with Oliver to have the tube Cut , i am expecting a prototype soon, will see ehat happens.
DAN ,
