Received a Warm Audio WA-67 microphone for repair.
The capsule was loose inside the head-basket
Upon inspection,
the capsule mount, which is made of some cheap and not flexible plastic, broke near the screw hole thus leaving the capsule loose inside the head-basket.
Or the center screw was overtightened at the factory or the plastic mount had already some production defect.
Anyway the type of plastic used is really easy to crack/break, so it can't be over-tighten,
I'm pretty sure the same thing will happen to other WA-67 microphones
The gold sputtering in both diaphragms was also damaged from the free rides, one side is worse than the other
Upon inspection,
