This has got to be a really poorly thought out mic then. I don't know how flat the dark K67 is, but I'm guessing way more high end is rolled off than is supposed to be due to the capsule.
Hello Whoops and thanks for your replies so far. Not trying to beat a dead horse here but if Warm say they copied the U-67 circuit, why does it look so different implemented and can you actually stray this far from a design and still have the expected results?....its been said in this thread the WA-67 circuit is exactly the same of the Neumann U67, only exception is the output capacitor which the WA uses an higher value than the original. But all the capsule de-emphasis circuit is exactly the same
Wow..This look like a great sounding room..!I’m recording today Andre Carvalho, a Doublebass player and composer.
It’s a really interesting project, it’s called Lost in Translation and each track is based on a specific word that exists in one language but has no direct translation to other languages.
It’s the forth record we do together
Here’s today’s setup with the Warm Audio WA-67 on low-end duties in the double bass
This is certainly a good microphone (especially for the money). Visually, I find it ugly, at least on photos. Does it also look so cheap in real life?does it?
Im not sure, the transformer is pretty good, it uses a good tube, the circuit is true to te original there’s just a different value in the output capacitor.
Capsule is wrong for sure,
And the PSU benefits of some work
Is not that far.
the capsule used will just make it darker than what it should be
We all have to keep in mind the price point, it’s a very inexpensive microphone.
The Neumann U67 reissue costs 5500€ , this mic costs 990€, for DIY people like us it’s really easy to do some small mods and make it very close to an U67
I think you are right, the bodyshape and rounded headbasket top makes it a little bit cheap looking. In the end, it is microphone for recording, not a foto model.I think it has more to do with the body shape, specially the rounded headbasket top.
Compared to the U67, it is a very BIG microphone.
I suppose they use the same body for the WA-87 (R2), which is (IMHO) not bad at all, but there is some room for improvement.
it looks like this because neumann slapped them with a C&D on their original design hahaThanks for feedback.
I think you are right, the bodyshape and rounded headbasket top makes it a little bit cheap looking. In the end, it is microphone for recording, not a foto model.![]()
