Mbira
I need to use relatively thin gauge wire - about 22 gauge is the biggest I can go...
These wires will be in pairs (positive and ground). They are attached with this molex connector, so there is a good positive lock:
http://www.mouser.com/Search/ProductDetail.aspx?R=502352-0200virtualkey53810000virtualkey538-502352-0200
The wire will be about 3" long and will be attached on both ends and moving in all 360 degree directions. The wire is attached to a marimba bar that is being struck, so the key bounces up and down and side to side a bit as it is struck.
Am I better off using stranded wire or solid wire? Ribbon cable? Twisting the pairs together? I think that eventually these joints WILL fail, and so I am planning on making these wires relatively easy to replace and making backups so they can be switched out as they break, but it'd make my life easier if I can find a solution that will work at least a couple months of regular action...
Edit: a little googling is telling me that stranded is what I want with vibration. I'm still not sure if I'm better off twisting the pairs or keeping them seperate...
