I don't know if a wall wart will solve the problem. I guess I need to find a lawyer to talk with.
Me too, as one entering the kit market. Casual observation suggests that practically the whole purpose of the wretched things is to avoid having to go through UL/CSA etc. It's been a while, but I have been through it with products, and small companies simply don't have the resources for that, unless something has changed.
I think the best liability protection for us is to simply make it virtually impossible for the home constructor to electrocute themselves or burn their house down, no matter what they do.
Kinda rules out tube mics, huh? Too bad.
I'll check more on this issue...you have me thinking about it.
Yes, but if I were you, I would first establish a detailed level diagram of the whole chain, and make sure that all the components clip more or less at the same time. This will give you a value for the sensitivity of the mic; then you have to work out all the parts. And probably find out you're asking too much. Getting an equivalent noise of 15dB and a max spl of 140dB computes to 125 dB S/N ratio, which is next to impossible to achieve in the current state of electronics, without some gain switching.
I've certainly done that. The biggest SPLs I see are drums...specifically cymbal crashes when close miced.
That's where I measure 140+. And of course this means mics basically putting out line level signals. Certainly 125 db s/n is at the bleeding edge of what modern line level converters/analog buffers can do.
I find the biggest noise contributors are room noise and pressure noise across capsule acoustic resistance anyway.
I'm just thinking it might be nice to be able to stick a condenser mic anywhere, like a 57 (which can do 175db+ in the midrange), turn down the preamp gain to just about nothing, and go. With no mic attenuators to fiddle with.
One might wonder about capsule mechanical overload, but modern designs like concave backplates can take care of a lot of that with fewer trade-offs.
I calculate max theoretical phantom power is when the load impedance equals source...6.81k/2.
170 milliwatts. Need switching regulators to use much of it. That would be 17
[email protected] some from efficiency, isolation resistors, etc.
Les
