the cores and bobbins are on the way but i still need to get a sample and wind one up before buying 1000 dollars worth of wire, so you vultures better cool your jets for a bit, undo the feeding frenzy thing until i proto type one. \
i jsut tried twisting some wire together, because it would be much cheaper. ths would work for one or two units, but it would be a real pain to do for 100 units.
the wire can kink up after twisting etc, so i think we don't want to go that route. plus, the pro wire will come in 4 colors which is cool for hookup.
so, let me slap one together, then if it scopes out, i will open up a black market thingy,
sound reasonable? I thought so.
also, Tommytones just "discovered" 100 transformers, whats up with that?
that needs to get sorted out also.
